Renault Clio Radio Code
Username: Reginald_swerrin
Hello,
Would be very grateful for the code to:
RNRD3450090441
8200409475T
Many thanks in advance.
Username: Hay88
PortsmouthUk
Post Number: 3019
Reginald_swerrin
please post the missing letter and three digits off the end of 8200409475Txxxx or the security code
That must be:
8200409475TX588
RNRD3450090441
Thanks
RNRD3450090441
8200409475TX558
renrdw220-00
FD03 0509 009 0441
Username: Hay88
PortsmouthUk
Post Number: 3020
please check
8200409475TX588 = 2416 you MUST hold at the end to store your code.
8200409475TX558 = 2415
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Then " 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Brilliant, thank you!
