Lost code for renault megane 04 plate
Username: Honeydew
Hi,
I needed a new battery & as you can already guess i lost my radio and don't have the code to reset it. The details are as follows:
Model No. 22DC277/62
TW368
RN277F30346813
Prod No. FD0303470346813
8200256141TW368
Sorry there's a lot of numbers, i just jotted them all down to make sure i had everything!
I would be eternally grateful if you could please let me know the code i need....i can't bear the silence anymore
Thank you
Username: Hay88
PortsmouthUk
Post Number: 3016
Honeydew
code 3673
Username: Honeydew
You're a legend! Thanks so much.
HAPPY CHRISTMAS!
Username: Nissan764
Hi,
I needed a new battery and i lost my radio and don't have the code to reset it.
T978
RN 277F40647176
PROD NO. FD0704370647176
VIN VF1KMR00632630686
BAR CODE 8200256141TT978
Many Thanks
Username: Hay88
PortsmouthUk
Post Number: 3025
Nissan764
code 6093
Username: Moto6
I had the same problem with my car and I solved it visiting kijiji.it,I found a cheap solution at http://www.escran.com/detail.asp?id=125858 and he/she solved my problem rapidly.Follow my way if you want and good luck!
Username: Hay88
PortsmouthUk
Post Number: 3028
AND IF YOU WOULD LIKE IT FREE STAY HERE.
IF ANYONE CAN HELP YOU THEY WILL.
Username: Nissan764
Thank you soooooo much hay88 ,you r star.
