Car radio code
Username: Lynnb
Hiya hay88
The only other numbers i wrote down are T00818 don't know if this is what you need if not it will be a day or two before i can supply anything else as i have to borrow pointy things again to get radio out. Thankyou any way for info so far - will get back to you as soon as possible,
Username: Hay88
PortsmouthUk
Post Number: 3001
Lynnb
if it's T0O818 = 1126 You must hold at the end to store the code.
if it's T0Q818 = 9120
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and hold buttons 6 to store. for 10 seconds
note the radio does not lockout after a wrong code entry it only doubles the time to wait before
the next retry...if a wrong code is entered it will display error then after the delay should display "0000")
Username: Lynnb
Hiya hay88
Code 1126 worked - thankyou so much - my car is quite old and now i wont have to listen to all the worrying noises it makes and just sing a long with the radio, tunelessly, in happy oblivion. thank you again.
