Need code for Becker BE4730
Username: Pat971
Hi
I replaced my battery without a bypass .
now my radio asked me for a code i dont have it .
can someone help me with this please.
model :BE4730
serial:35068426
many thanks
Patrick
Username: Hay88
PortsmouthUk
Post Number: 2978
Pat971
code 23642
Username: Pat971
ty for the fast answer i gonna try it right away .
let you know of it worked .
ty so much .
Username: Pat971
i doesnt work it says code wait .
can someone explain what that means
Username: Hay88
PortsmouthUk
Post Number: 2990
i have sent you a message
Username: Pat971
its a BECKER TRAFFIC PRO BE 4730 FORD
Username: Hay88
PortsmouthUk
Post Number: 2991
yes i know :-)
If the display continually shows "CODE WAIT" then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible
