Gold Member Username: SkdooleyRoanoke, VA Usa Post Number: 1309 Registered: Oct-09 | What do you guys think about this sub? I've kind of made my mind up that I wanted the rl-p 12 but the specs on the treo look good. I want a sub with a low Fs for good low end and good output. I plan to run a nine.1 at 2 ohm. |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 16054 Registered: Jun-04 | why dont you buy my stereo integrity mag 15 it has a fs of 22 hz. T/S parameters: 15 inch Re (coils in series) 3.5 Fs 22 Le 3.7 Qms 3.7 Qes 0.39 Qts 0.35 Cms 197 Mms (grams) 262 Vas (liters) 184 Sd (cm^2) 810 BL 18.35 SPL (1W/1M) 88.8 Power handling RMS 950 Recommended enclosures: 15 inch Sealed 2.3 to 3 ft^3 Ported 3.5 ft^3 tuned to 30 Hz DUAL 2 OHM. |
Gold Member Username: Snowball123West Allis, WI Post Number: 3593 Registered: Oct-07 | Maybe he can't fit a 15"? |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 16055 Registered: Jun-04 | we will find out I guess. |
Silver Member Username: CenusPost Number: 220 Registered: Aug-08 | honestly id take the rlp over that treo sub. if it was the ssi or ssp watever its called now would be a better comparison. |
Gold Member Username: SkdooleyRoanoke, VA Usa Post Number: 1310 Registered: Oct-09 | I was thinking of a 15 but I'd like to keep the enclosure to 2.5 cubes or smaller. If there was a 15 that would do ok in a smaller enclosure that would produce good low end I'd be interested. |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 16056 Registered: Jun-04 | you could put the mag in a 2.5 sealed enclosure and put polyfill in it and it would hit the low end very well because it would function as a box that was 3 cubic feet |
Gold Member Username: SkdooleyRoanoke, VA Usa Post Number: 1311 Registered: Oct-09 | Where would I find a mag 15? That's kind of a problem with the Sound Splinter subs, they're hard to come across. The only ones I've found still for sale are the rl-p12 d4's. |
Gold Member Username: SkdooleyRoanoke, VA Usa Post Number: 1312 Registered: Oct-09 | I'd really like a rl-p 15 is anyone knew where to find one, new or used. I'd sacrifice the space for a good 15. |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 16057 Registered: Jun-04 | Where would I find a mag 15? I have one. interested? |
Silver Member Username: CenusPost Number: 222 Registered: Aug-08 | sean- there is no way you can figure that, yes adding pollyfill makes the sub think the enclosure is bigger but its impossible to figure how much bigger. skd- only subs id know of that work well in small boxes is tc sounds drivers, but they can be very exspensive. |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 16058 Registered: Jun-04 | I can prove that you can....it will see 3 cubic feet with the right amount of polyfill dustin |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 16059 Registered: Jun-04 | http://web.archive.org/web/20020808224043/integra.cyberglobe.net/caraudio/resour ces/fiberfill/ |
Gold Member Username: SkdooleyRoanoke, VA Usa Post Number: 1313 Registered: Oct-09 | I googled rlp-15 d2 and found someone who was looking to trade a near mint one, for a rl-p12. I messaged the guy to see if he is looking to sell it. I'll keep the mag in mind, I do like the specs. How much would you want for it? |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 16060 Registered: Jun-04 | that link doesnt work try this one http://web.archive.org/web/20020808224043/integra.cyberglobe.net/caraudio/resour ces/fiberfill/ |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 16061 Registered: Jun-04 | 235 shipped |
Silver Member Username: MakinblakMonroe/Monticello, La/Ar Post Number: 192 Registered: Oct-10 | sean, i looked over that website, and have a stupid question: when stuffing my box, do I staple it to the walls or just throw it in the box with a screen across the port? |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 16063 Registered: Jun-04 | you staple it to the walls in a ported box |
Silver Member Username: CenusPost Number: 223 Registered: Aug-08 | that site doesn't prove anything, i could make a web site and throw some numbers around. doesn't even say how he figured all that. |
Silver Member Username: JbpittPittsburgh, Pa. Usa Post Number: 962 Registered: Jul-09 | Go for the Mag 15. Excellent price,great sub and seans a good guy to buy from. |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 16064 Registered: Jun-04 | well dustin your just a dumb a $$ then.... we proved that |
Gold Member Username: SkdooleyRoanoke, VA Usa Post Number: 1314 Registered: Oct-09 | Do you have any good pictures of the sub? |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 16066 Registered: Jun-04 | yes one let me get it |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 16067 Registered: Jun-04 | |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 16068 Registered: Jun-04 | it was dusty in that photo but it cleaned up nice later |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 23956 Registered: Jun-06 | Gaining "apparent" sub enclosure volume using poly DOES have positive effects. The bottom line value can, and ever will be, an arguable one however. Some sites state an increase of as much as 30% is possible while others say less than 10% is a safe bet. I've used poly, carpet padding and even fiberglass insulation on the insides of some of my boxes with positive results. (The insulation not being recommended of course lol). Some wise men say a statement is fact until it is disproven. Others say how can you state fact on anything that isn't completely understood? Case and point. According to Einstein time travel is possible within the confines of his theory of relativity. Until we "understand" and PROVE the universe and its' laws completely we just have to accept that time travel is indeed possible according to his genius. My point and advice after all that? Stuff it. |
Silver Member Username: CenusPost Number: 224 Registered: Aug-08 | yep im a dumbass. lmao atleast i knew wat version mag you have their sean i remeber a thread where u told me u have the xbl^2 version lol which you dont. Keep posting stupid links showing some numbers an percent signs fool all the newbs. Keep up the good work. |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 16070 Registered: Jun-04 | lol loser....you cant do better than that....at least you agree with me that your a dumb a $$...by the way you didnt no it wasnt an xbl motor either idiot. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 11586 Registered: Jul-06 | IMO the mag is the best choice... and sean's is a reasonable price |
Silver Member Username: CenusPost Number: 225 Registered: Aug-08 | lol anyway back to OG topic treo sub isnt comparable to the other subs listed maybe if it was the ssi. The mag an rlp are very close performance/build quality wise. Me personally would take the rlp but i like tc designed subs so. |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 23961 Registered: Jun-06 | Fug. Mag SS Treo TC Do we really have a loser here? |
Gold Member Username: SkdooleyRoanoke, VA Usa Post Number: 1315 Registered: Oct-09 | I found a guy with a SS rlp12 d4 willing to sell it for $180 + shipping. I havn't seen any pics of it yet though, so I'll see what kind of shape its in. |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 16077 Registered: Jun-04 | good find |
Silver Member Username: NissankickerGrambling, LA USA Post Number: 315 Registered: Mar-06 | The Treo TE is the remaked version of the TSX... I have experience with the TSX 12s... They hit VERY hard, and give out GREAT lows. You just can't put the juice to them. I did 2 12" Treo TSXs in a 5.5cuft Tuned @ 33hz - they could find a niddle in a hay stack ( Meaning they were pin-point accurate on all notes that came across them. And sounded GOOD doing it ) .... And I also did 1 12" TREO TSX in a 3.0cuft @ 35hz - I have yet to hear a single budget sub hit that aggressively & not show a sign of fatigue. If I can find the picture(s) of the setup's I'll post them. |
