Renault Megane Radio Code
Username: Petethegreek
Just bought a Megane and need the code.
Barcode on the Philips unit is 7700 433 072 T090
Any help would be greatly appreciated
Username: Hay88
PortsmouthUk
Post Number: 2892
Petethegreek
code 6906 you must hold at the end to store the code.
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and hold buttons 6 to store. for 10 seconds
Many thanks Hay - That worked a treat .
Username: Jayzee34
Hi
My car battery was replaced and now its asking for a radio code.
All I can my find on the radio:
Model no: 22DC277/62
TR933
RN277F30345624
Prod no: FD0303470345624
8200256141TR993
Please help. It will be much appreciated!
Username: Hay88
PortsmouthUk
Post Number: 2958
Jayzee34
if r933 code 8048
if r993 code 8040
Username: Jayzee34
Hi hay88, i tried 8040 for R993 and it worked! You're a genius and i'm so happy and thankful for the help you've provided. Have a Merry Christmas! Regards, Jay.
