Renault scenic code
Username: Niko87
Please please please
Having problems getting radio code after my mum replaced battery in her Renault scenic. Dealer wanted 25, I'd be so grateful if anyone could help.
Serial. Rnrd0440133398
Security. T944
Cheers guys!
Username: Hay88
PortsmouthUk
Post Number: 2921
Niko87
code 6010
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and hold buttons 6 to store. for 10 seconds
Username: Niko87
You are an absolute diamond mate. Thanks for such a quick response!
