Hi, i was just wondering if anyone could help as my renault clio 2002 just had its alternator replaced which now means I have to get a code for my radio.
This is what I can see on my radio : Model No: 22DC278/62B
Haza if TOI675 = 0172 YOU MUST HOLD AT THE END TO STORE THE CODE. If T0L675 = 2773 Code Entry as Follows:
Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
