can someone supply me with instructions how to input codes in the radio the radio shows error7 and cant do anything else even if i take power off when i reconnect it goes back to error7 please? domenic1
Please note that code entry is only possible when the display says " CODE IN ". If "ERROR" is shown on the display, then the stereo is codelocked. If this is the case, leave it switched on for up to two hours and a further attempt at code entry should be possible. Error 7 mean's 7 wrong codes have been entered
thanks for the reply i have left it on for half hour and i then got four ---- ican put numbers in but everytime i get an error with eigher no meaning now after 3 tries the error code is 10 i tried once more and it come up with 11 error obviously i have the wrong code for this radio. does anyone know how to git the correct code for this radio? model PU-2294A c CL040120830710 I HAVE BEEN ASKED 20 POUNDS TO GET THEM onlyne i am a bit weary about this and considering i have paid 30 for the radio i dont know if its worth it. i would appreciate some help and would be greatful to anyone with help. domenic1
if you got a barcode that starts with C7 Then i can help. if not Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM) to get the right code.
