Radio code help please
Username: Justluvshopping
My 02 C180K Merc went in for service monday & the mechanic hit reset to factory settings via the computer. I think this has cleared my radio as the screen now shows: Audio - - - - and for all intents & purposes the radio (and my phone) are dead but are getting power
The radio is a Becker Audio 10 Serial No BE602128100805
I'd really appreciate it if someone has a code & can tell me how to put it in (can it be done via the number pad on the telephone because the book kinda indicates it can)
Thanks so much in advance
Username: Regrooster
Post Number: 5589
try code 1 6 6 2 1
Entered directly using preset buttons
Thank you. I don't have preset buttons as such, just a cross shaped thing with 1-4 on it. I did try to enter the numers given using that ie. 6 = 2 x 2 but it doesn't appear to be accepting that and I think it's a four digit code as it just has four dashes on the screen.
Username: Hay88
PortsmouthUk
Post Number: 2960
i sent you a email yesterday did you get it
Yes thank you hay88. Again I did try to enter both the codes you gave me using the cross shaped button and via my telephone pad but neither worked. I will just book it into a Merc. dealer I guess but thank you both again for your help.
