Hi Everybody, My radio locked becuase of battery unplug, please, help me with the code! Laguna2 (2002) Model:22DC279/62Z T0H224 RN279F20298080 Prod:FD0202230298080 8200002607TH224 Thank you, in advance!
Kruno888 code 0809 you must hold at the end to store the code. Code Entry as Follows:
Switch Radio On - Display Shows " CODE " Then " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
Just brought my Laguna Sport 2000 But the battery was dead so like everyone else no stereo Can ANYBODY PLEASE HELP ME ? Model: 22DC279/62 Prod No: FD0100220067592 T0Z000 RN279FY0067592 Thanks Please Help
Hi code 0905 you must hold at the end to store the code.
Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
