Silver Member Username: Bazuka2020Post Number: 936 Registered: Oct-05 | Hope someone would help me I changed my ISp to bell and no TV since then I was fine before that wondering something has to be changes my Ihub is connected and working fine |
Diamond Member Username: NydasPost Number: 20124 Registered: Jun-06 | Bazuka: https://www.ecoustics.com/electronics/forum/home-video/660273.html Read this thread about Bell Modem. and investigate. Se if you can get going, otherwise post again. |
Silver Member Username: Bazuka2020Post Number: 938 Registered: Oct-05 | Thanks nydas will try after absorbing and will post before I do that want to know are we up or down |
Bronze Member Username: TansarbhPost Number: 87 Registered: Oct-08 | Bell gives you static IP addess so, you have to connect with hub to other computers etc. Are you on private or public server? |
Silver Member Username: Bazuka2020Post Number: 950 Registered: Oct-05 | Thanks everyone it wasNot the ISP issue it'S solved now |
