code 0597 HOLD AT END TO STORE CODE Code Entry as Follows:
Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
Will_stable your code 6407 Code Entry as Follows: Switch Radio On - Display Shows " CODE " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press Preset " 6 " to Enter
Hi, I need help to. After changing the battery, the radio wanted a code to start. That is something that I don't have, please help! Model no:22DC481/62 Prod no:FD 1099049097683
hi post the numbers/letters from below the main barcode something like 7700xxxxxxt123 or 8200xxxxtt123 or the security code like Q123 or T0U123 can be found in a small box then i can help you
OK. Here are more numbers: Renault <276> Radiosat 6000 7700 433 070 --- Philips 22DC481/62 9022 214 81629 7700433070V162 written under the EAN-code I hope that something of the above will help you. Thanks in advance from Sweden
A_mannen youe code 4811 you must hold at the end to store the code.
Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ] button then rotate the thumb wheel for the correct first digit Press the [ ] button then rotate the thumb wheel for the correct second digit Press the [ ] button then rotate the thumb wheel for the correct third digit Press the [ ] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL press the first preset button for the 1st digit, second button for the 2nd digit third button for 3rd digit forth button for 4th digit then press and hold buttons 6 to store. for 10 seconds
