Silver Member Username: IndopakPost Number: 160 Registered: May-06 | Hi sada i have a ilink 9000+ is not working right now with Indian channel is there any way to get the Indian channel on this receiver please let me know Thanks |
Silver Member Username: KrishnPost Number: 371 Registered: Sep-06 | Are you trying to hook it up on Private or Public server? |
Silver Member Username: IndopakPost Number: 161 Registered: May-06 | Yes i can do that if is work |
Silver Member Username: KrishnPost Number: 372 Registered: Sep-06 | It works on both, Private is $35 at NFPS through Sada, public is free but international channels are limited - you have to decide, Not sure if you can hook up ilink to both private and public and be able to switch, may be Sada can clarify Also do you have the dish pointed at 118 - with special LNB and large size dish 33 inches or larger |
Silver Member Username: IndopakPost Number: 162 Registered: May-06 | That good news so please tell me what should i do to get that channel back and yes i do have a 33" dish and is setup with 118 Thanks |
Silver Member Username: KrishnPost Number: 374 Registered: Sep-06 | If you want private then PM sada, on public it is very limited |
Silver Member Username: IndopakPost Number: 163 Registered: May-06 | how do I PM sada |
Silver Member Username: KrishnPost Number: 375 Registered: Sep-06 | https://www.ecoustics.com/cgi-bin/bbs/board-profile.pl?action=view_profile&prof ile=saqeeb9000-users click on - click here to send private message in the above URL |
Silver Member Username: KrishnPost Number: 376 Registered: Sep-06 | Upadte - if your i-link 9000 is new it may not work see this URL: http://iksprivateserver.com/ilink-guide/ |
Silver Member Username: IndopakPost Number: 164 Registered: May-06 | Thanks Subash |
Bronze Member Username: KrishrgmxcomPost#462 Post Number: 98 Registered: Dec-10 | . |
