Blaupunkt
Username: Ribeiropa
Hello.
Could you help me finding the code for an original Citroen Xantia mk1 Blaupunkt?
Blaupunkt PH1/D
96 260 240 80
Username: Regrooster
Post Number: 5568
post all the letters+ numbers on any labels or stamped in the metal casing
Username: Ribeiropa
BP2492S0768020
Ministereo P.T.
(D.M. 25.06.1985)
(D.M. 27.08.1987)
N.9/02195/17412
Username: Hay88
PortsmouthUk
Post Number: 2812
Ribeiropa
code 7953 / 0505
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press Preset " 6 " to Enter
