hi was wondering could somebody help me with my 4 digit radio code renault megan scenic model number= RENRCW131-10 TOT 186 RNC043005642 PRODUCT NUMBER= FD0003370005642 8200300855TT186
Hello House Thank youvery much all for helping out like this. I have a similar problem need radio code for our renault megane 1998 model # 22DC479/62 production # 0798179037849 U544
Monument9 if thats security code.U544= code 5434 if not please post numbers/letters from below the main barcode something like 7700xxxxxxt123 or 8200xxxxtt123 or the security code like Q123 or T0U123 can be found in a small box then i can help you
Hi, anyone please help me sort a code for my Corsa with a Grundig car 200 (D). Dad says the serial code is : GM0200X7893277 Will love you forever....................hugs !
Post Number: 1 Registered: Nov-10 Posted on Friday, November 12, 2010 - 12:18 am: Hi there, Been looking a an unlock code For radio in Mercades Benz Sprinter 2000 Model.
Eurovox SN 359029791.2. Model 4115 MOD4115MB1
I think it is a 5 digit code. thanks heaps! marco.gdfo@hotmail.com ====================================================
Eurovox codes are only available from the Main Merc Dealer or a Radio Decoding Service
Post Number: 2 Registered: Nov-10 Posted on Friday, November 12, 2010 - 03:43 am: Hi, anyone please help me sort a code for my Corsa with a Grundig car 200 (D). Dad says the serial code is : GM0200X7893277 =========================================== Sorry....Main Dealer or a Radio Decoding Service only for this code
Posted on Thursday, November 11, 2010 - 03:31 pm: Monument9 if thats security code.U544= code 5434 if not please post numbers/letters from below the main barcode something like 7700xxxxxxt123 or 8200xxxxtt123 or the security code like Q123 or T0U123 can be found in a small box then i can help you
thank you Hay88 here is the info under the main barcode.Thank you very much in advance. Renault Megane
Hi i was wondering if someone could help me. my radio doesnt work anymore i need my radio code. my car is an Honda Civic 2008. I did that 1 and 6 thing and it gave me my serial number : 2613 7393. thank you very much
============================================= If you CANNOT find a code written on the radio or on a card in the glovebox (or similar "hidden" place ) then please read on
Please note:
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT. These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
So you will be wasting your time posting code requests here for any other make.
BLAUPUNKTS ONLY with a BP Serial Number
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Hello Hay88 like you asked me to i found out the # under the main barcode. Its a phillips radio on our renault megane 1998 Model under the barcode this is what i found # 7700 426 484 U544
and this is the rest of the info already posted earlier model # 22DC479/62 production # 0798179037849
Monument9 your code 5434 you must hold at the end to store the code. Code Entry as Follows:
Switch Radio On - Display Shows " CODE " Press " A " On The Stalk Control To Enter " 0000 " Rotate " Thumbwheel " For Correct Digit Press " A " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " A " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " A " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " A " Until A Beep Is Heard
Igorbg 8200247962TC326 = 0634 you must hold at the end to store the code. Code Entry as Follows:
Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
note the radio does not lockout after a wrong code entry it only doubles the time to wait before the next retry...if a wrong code is entered it will display error then after the delay should display "0000")so leave it turned on until it resets itself.
I have bought a 1997 Renault Megane and have no code for the radio. Could anyone help me with this please? Model: 22DC449/62L 7700426414G256 Product: FD0097264001896
you need to remove the radio. they are too small holes each side of the radio use an old metal coat hanger 4 darts or very small screwdriver or long nails. put into holes about 4-5cms and push outwards sideways and carefully pull radio forward. you must do the holes on each side at the same time
Then post the numbers/letters from below the main barcode something like 7700xxxxxxtt123 or 8200xxxxtt123 or the security code like Q123 or T0U123 can be found in a small box then i can help you off of the radio
Post Number: 1 Registered: Nov-10 Posted on Saturday, November 13, 2010 - 06:26 pm: Bought used 1999 Honda Accord Coupe V6 radio does not work need code. P/N:39101-S82-A220-M1 REF.NO.:MF928A0 S/N:F90336451
Sorry...Main HONDA Dealer or Radio Decoding Service only for most Honda Codes
Post Number: 2 Registered: Nov-10 Posted on Saturday, November 13, 2010 - 03:09 pm: Lost my radio code for a 93 audi s4 serial number is AUZ1Z7P3903964. can anyone help please and thank you. ==========================================
Sorry....Main AUDI Dealer or Radio Decoding Service only for this code
hi again everyone got another one for ya? renault clio 1.2 on a 02 plate model no. 22dc278/62b prod no.. fd0804100764978 sec.. RN278f40764978 sn.. 8200057681tv154 many thanks justin.
Hi. Can you help - after having a new alternator fitted, I now need a radio code in my Renault Scenic 2002. Model No 22DC258/62P Product No FD0102220051862
Other numbers Toy526 RN258F20051862 8200152345 TY526 0051862 029021
All, If you are trying to get a unlock code for your radio stay away from the following internet company, radio-code.com. This site will only take your money with nothing in return. Site looks good and promises are guaranteed with 24 hour turn around but don't be fooled. Radio-Code.Com has no address are telephone number shown for you to contact their staff. All they show is a email address for customer service. If anyone knows the location of this business city and state please let know.
Jane01 your code 1479 you must hold at the end to store. Code Entry as Follows:
Switch Radio On - Display Shows " CODE " Press " " On The Stalk Control To Enter " 0000 " Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
please can anyone help ? renault clio 1.2 on a 02 plate model no. 22dc278/62b prod no.. fd0804100764978 sec.. RN278f40764978 sn.. 8200057681tv154 many thanks justin.
Looking for radio code for '96 Saab 900SE Serial on radio: YS4929R2028918 VIN on car: YS3DF35N4S2025487 If anyone can help would be much appreciated. Thanks
Seems like you're the guru here who may be able to lead me back to the blissful experience of car audio. I just replaced the battery and now need the radio code in my 1997 BMW M3 Harmon Kardon System Serial# T0762251
i recently purchased my Vectra C and pulled out the CD system not knowing i'll need a security code once put back in. i found a code on a card in the manual folder but that code didnt work. Can you plz give me the code for Siemans CDR2005 from 2004 Vectra Sxi: -
Naz3k3 Sorry....Main Dealer or Radio Decoding Service only for this code. are you entering right. Code Entry as Follows: Turn Off Stereo Press & Hold Preset " AS " and Switch Radio On - Display Shows " SAFE " And Then Shows " 10 - - - - " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press & Hold Preset " AS " Until the Unit Beeps
Oscar_gr code 1874 you must hold at the end to store the code. Code Entry as Follows:
Switch Radio On - Display Shows " CODE " Then " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
Hey, just bought a new car and the original stereo lacks a code as the previous owner used his own and didn't realise when he put it back in to sell.
The information I can find on the unit is:
7 648 247 380 014AUZ1Z3X6061372 AUZ1Z3X6061372 480 035 186 C
It's a Blaupunkt Concert tape deck from a '99 Audi A4. Let me know if you need any more information and I'll endeavour to get it. Thank you in advance! :-)
code 1180 you must hold at the end to store the code. Code Entry as Follows:
Wanted to give you my experience on obtaining radio code for my Honda Radio. After searching all over different sites for a code and I appreciate all the help and input I got on this site. I finally went to a Honda Dealer site here in Dallas. Sent them a email with model and serial number of radio in 15 minutes I got back a reply with the code, radio works great. Sometimes you just got to go back to the source. Thanks to all for their help and stay away from companies like radio-code.com..
Hi, I'm installing an ipod adapter on my 2000 Audi TT with Concert radio, I don't have the code, please help. serilal AU5Z6X0143794 VIN TRUUC28NXY1031501 many thanks in advance. Carlos
Post Number: 1 Registered: Nov-10 Posted on Wednesday, November 17, 2010 - 07:37 pm: Hi there, i need a code for: Opel Corsa C DELCO CDR 2005 VDO GM0205Y9072887 24423497 --------------------------------------------------------------------------------
DELCO codes are only available from the Main Dealer or by using a Radio Decoding Service
Post Number: 1 Registered: Nov-10 Posted on Wednesday, November 17, 2010 - 01:49 pm: Hi, I'm installing an ipod adapter on my 2000 Audi TT with Concert radio, I don't have the code, please help. serilal AU5Z6X0143794 VIN TRUUC28NXY1031501 many thanks in advance. Carlos ------------------------------------------------------------------------------
sorry...Main AUDI Dealer or Radio Decoding Service only for this code
I also have an 02 Audi A4 I just bought a symphony 2 head and the seller didn't have the code for it. Ser #: AUZ5Z4D5386843 the vin# for the car it came from is : WAULC68EX5A063533 . don't know if these numbers help but they are on the sticker on the side. 8E0 035 195 H and CQ-EA1360L any help would be appreciated (dealer wants 70$ to tell me what it is!)
Post Number: 1 Registered: Nov-10 Posted on Saturday, November 20, 2010 - 07:09 pm: I have a 02 Audi A4 and need my Symphony II code if any one can help me out. vin# WAULT58E62A307149 and radio S# AUZ5Z4A5085983
haiduc New member Username: Haiduc
Post Number: 1 Registered: Nov-10 Posted on Saturday, November 20, 2010 - 09:47 pm: I also have an 02 Audi A4 I just bought a symphony 2 head and the seller didn't have the code for it. Ser #: AUZ5Z4D5386843 the vin# for the car it came from is : WAULC68EX5A063533 . don't know if these numbers help but they are on the sticker on the side. 8E0 035 195 H and CQ-EA1360L any help would be appreciated (dealer wants 70$ to tell me what it is!) ---------------------------------------------------------
Sorry.....these codes are only available from your AUDI Dealer or a Radio Decoding service
hey can you get my radio code please?! my battery was taken out of my car and cant get the radio on again! renault megane 2001 plate serial no- VF1BA0B0525023548 Thanks in advance!
hey i really need help i have a 99 integra but cant find my radio code the serial number is 96g400310 and the model is 39100-st7-c500 if you could help me it would be greatly appreciated thanks
Post Number: 4 Registered: Nov-10 Posted on Tuesday, November 23, 2010 - 10:05 am: Hello House ive got a Delphi radio here asking for a code pls help out,thank you all and remain blessed.
Delphi s/n 93801884
Under the bar code Gm 017783
Joaquin New member Username: Jcuevas06
Nyssa, OR 223
Post Number: 1 Registered: Nov-10 Posted on Tuesday, November 23, 2010 - 03:23 pm: hi i just bought a vw 1999 passat safe is on the radio code vwz9z7w6024778 radio model pu-1634A clarion car vin wvwna63b0xe282852
StephieJ New member Username: Stephiej
Post Number: 1 Registered: Nov-10 Posted on Wednesday, November 24, 2010 - 11:57 am: hey can you get my radio code please?! my battery was taken out of my car and cant get the radio on again! renault megane 2001 plate serial no- VF1BA0B0525023548 Thanks in advance!
Tyler New member Username: Tharwood01
Post Number: 1 Registered: Nov-10 Posted on Wednesday, November 24, 2010 - 03:12 pm: hey i really need help i have a 99 integra but cant find my radio code the serial number is 96g400310 and the model is 39100-st7-c500 if you could help me it would be greatly appreciated thanks
the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
