New member Username: Jeremyfromont
Post Number: 1 Registered: Dec-10
Posted on Bonjour j'ai changé ma batterie et j'ai perdu le code de l'autoradio de ma 147 ! pourriez-vous m'aider ? BP NR : 7 643 301 316 Fiat NR : 156 053 469 Cordialement. |
Gold Member Username: Hay88
PortsmouthUk
Post Number: 2877 Registered: Mar-10
Posted on Jeremyfromont post the main serial BPxxxxyxxxxxxxx can be found stamped in to the metal casing |
Post Number: 2 Registered: Dec-10
Posted on 815BP330158346519 ? |
Post Number: 3 Registered: Dec-10
Posted on BP330148346519 in to the metal casing |
PortsmouthUk
Post Number: 2880 Registered: Mar-10
Posted on Jeremyfromont (immo) code 3323 |
Post Number: 4 Registered: Dec-10
Posted on ca fonctionne ! merci beaucoup !!! |
