Suggestions puttin subwoofers in a truck
Username: Cblaze
Mcminnville, Tenesssee Us
Post Number: 2107
i got a single cab 04 dakota...wanna put a couple 10's ported in it or something.whats out there that sounds pretty good for a decent price. needs to have a decent mounting depth tho.i wanna get a 1500 watt rms amp
2 or 3 years ago i had a sx 15 ported at 32hz in a blazer.so i like it loud and low...i know i will not get that loud tho without loosing alot of seat room.but i need the leg room
its got 2 bucket seats in it.it does have a middle console in it but ima try to leave that alone if i can.if i pulled that out i would have a 12 inch re sx but i wanna try to leave it alone
Username: Nd4spd18
Philadelphia, PA
Post Number: 11556
2 sealed 10"s is what I always do in single cabs... theres not space for a ported box usually. And depending on what subs you use you may only need 1000w or so... of course having a 1500w amp would be great then, amplifier headroom = win
Username: Cblaze
Post Number: 2108
ive never been able to get sealed subs loud enough for me in a single cab truck.a 12 inch sx only takes 2 sq ft ported. ima try to figure out how to make it fit
Username: Cblaze
Post Number: 2112
well whats some good 10's that get pretty loud .was thankin l5s but im open to suggestions
