Hi this is my first post here. Just wondering what would be a great amp to power up one or two UL12 critical mass speakers. I have 4 of them so maybe I can get two amps or 4 Amps which ever is the best choice. Here are the specs for those of you who don't know. Thank you for your time.
RMS Power handling: 2500 Watts (undistorted power) Peak Power handling: 5000 Watts Recommended Box Volume: 1.2 cuft. (Sealed) Weight: 16.6 lbs Motor Type: Dual Gap / Internal NEO Magnet Voice Coil Type: Ultra-High Temp Dual Coil (Made in the USA) Voice Coil Diameter: 3" Voice Coil Impedance: 1.5 ohm nominal per coil Xmax (one-way linear excursion): 36 mm (3" peak-to-peak) Maximum Excursion (one way): 46 mm (Almost 4" peak-to-peak) Sensitivity: 96.7 db (2.83V / 1m) (coils in parallel)
