Can someone help me with a code for my s reg renault megane coupe
Username: Johnlang62
i need a radio code for this radio as i changed the battery and no longer have the service book as im the 4 th owner .
barcode on radio is7700 426 414 n374
its a renault radiosat 4000
i think the model num is 2220449/521
Username: Hay88
PortsmouthUk
Post Number: 2722
Johnlang62
your code 2694 you must hold at the end to store the code.
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
