Clifford Concept 650 MkII
Username: Fat_ed
Hi there, I have recently bought a second hand Clifford Concept 650 MkII alarm system which I am trying to fit into my 2003 MG ZR 2.0TD. I am fine with all of the connections other than the 8 black wires that are for the immobiliser/power for the main unit of the alarm. I have downloaded the installation guide for the alarm and it says that there should be 2 4-pin blocks connected to these wires which are ...
H4 Plug Connector (female)
12v Constant
Earth/Ground
Earth/Ground
Light Flash Input
H3 Connector (male)
Starter Car Side
Starter Key Side
Ignition Car Side
Ignition Key Side
I just wondered if somebody on here could point me in the right direction as the which wire is which as if you take the top cover off the main alarm unit the wires are numbered 1-8 on the circuit board but not in numerical order. It would be excellent if someone could tell me which number on the main board corresponds to on the list above.
Thanks in advance,
Ed
Need to Register?
Forgot Password?
Enable HTML code in message
