Radio code
Username: Reunbleiz
Hi,
Could you give me the code for my radiosat :
RENRDD100-00
RNRD1650045232
PROD No: FD0205290045232
8200403537TW380
Thanks
Username: Hay88
PortsmouthUk
Post Number: 2688
Reunbleiz
code 3612
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
