In DESPERATE need of a code for my Renault Clio
Username: Pinky88
Hiya......
I really need a code for my car radio.
I took the details off it:
Model no: 22dc259/62f
Product no: fd041070325537
Can anyone help?
Username: Hay88
PortsmouthUk
Post Number: 2670
hi post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
Username: Pinky88
Is it this: 8200029539tf820
Username: Hay88
PortsmouthUk
Post Number: 2679
Pinky88
code 2764 you must hold at the end to store the code.
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Username: Pinky88
Omg! It worked. Thank you sooo much!
