hi i need a code for my renault radio/cassette player . The numbers i have are... Model 22DC461/62L FD119922 4206798 7700433072Q694 SERIEL NUMB. RN4B1FX4206798
1967mrdee code 9302 you must hold at the end to store the code. Code Entry as Follows:
Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
