Renault megane scenic 1998 radio code
Username: 1967mrdee
hi i need a code for my renault radio/cassette player . The numbers i have are... Model 22DC461/62L FD119922 4206798 7700433072Q694 SERIEL NUMB. RN4B1FX4206798
Username: Hay88
PortsmouthUk
Post Number: 2678
1967mrdee
code 9302 you must hold at the end to store the code.
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
