Hi, could anyone help please, my '98 Megane Scenic is needing a code after disconnecting the battery. There are lots of numbers on the radiowhich I've written below Radiosat 400 7700 426 414 (R903) Philips 22DC449/62L 9022 214 49624 FD 05 97 49 4076431 Code gravage 4076431
code 8047 you must hold at the end to store the code. Code Entry as Follows:
Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
