Headunit and cd changer
Username: Stnorris
Fully Loaded BL 15?, IA US
Post Number: 2291
I am looking at buying a vehicle but it has a 6 disc cd changer. There are not dash kits made yet to swap this out with an aftermarket HU.
I want to install the system I already have which is 2 amps, components, a Fi BL 15", and a nice Pioneer Head unit.
My question is, is it possible to custom install my Head unit below the cd changer and be a completely seperate system from the stock system since I am using components???
Any ideas how I would do this?
Username: Canaanwhite
Monroe, Louisiana USA
Post Number: 81
what vehicle are you buying ?
Username: Glasswolf
Post Number: 14111
that's one option, as is using a JL Audio Cleansweep or Audiocontrol LC6 or similar product to use the stock head unit with everything else
Username: Stnorris
Post Number: 2292
@glasswolf.
I have a high end pioneer HU, 5v, 3 rca outputs so i want to use this.
If i get my HU custom mounted below everything else, am I able to just power the HU on a wire to the fusebox and then just wire the rcas and everything like normal off the HU?? Im not worried about the radio on my pioneer.
Sorry, not too knowledgeable on something like this.
Username: Nd4spd18
Philadelphia, PA
Post Number: 11521
Yes you can do that. It's fairly common actually on cars with heavily integrated stock systems.
Post Number: 100
What vehicle are you buying...I know most vehicles on the market...Also does it have BOSE ...Infinity...or JBL already installed and does it have onstar? All these factors can play on hooking it up...I can make any radio look good and work perfect in any vehicle
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 15866
if only that was true
Post Number: 264
the Scosche loc converter that is sold at Wal-Mart is the best LOC for the money...you can go that route
