| my amp is 1000w and it say it is 200W x 1 Continous Power Output (4 Ohms)...but my sub is 1000w 4 ohms...how do i wire it? |
The$Money$Man | Well U have to tell me what ur amp puts out at lower impendances.What does it put out in 2 ohms?1ohms if applicable?bridged @ 4 ohms? |
| well i dont know the numbers but hears the site man... www.kenwood.ca Key Features - Maximum Power Output: 1000W - Aluminum Die-Cast Frame - Class D Mono Amplifier Design - 200W x 1 Continous Power Output (4 Ohms) - 400W x 1 Continous Power Output (2 Ohms) - 500W x 1 Continous Power Output (1 Ohm) - MOSFET Switching Power Supply - Built-in Variable Low-Pass Filters (50-200Hz) - Built-in Infrasonic Filter @ 15Hz/25Hz (18db/oct) - Bass Boost (Off / +12dB at 90Hz) - Variable Input Sensitivity (200mV-5V) - Gold Plated RCA Inputs - Gold Plated Terminals - 2-Year Warranty |
The$Money$Man | This amp is not 1000 w Rms its 500x1@1 ohm but If you want to get all the power out of it take the sub Im assuming its dual 4 ohm voice coils and wire it in parallel run a wire from the + to the other + then run another wire from the - to the other - After that take like a 8 gauge wire and run that from one side or ur sub's + and - and then run those wires into ur amp's + and - channels this will give u a 2 ohm load not 1 if u wanted a 1 ohm load u would need 2 Dual 4 ohm subs.So in the end this amp will put 400x1 out on that sub continous power you may wanna think about gettin 2 amps lol by the way what kind of sub do you have |
| shitty..im sub is a 10' db+..the rms is 250w,if that will make a differnce..and its only a single voice coil.. |
The$Money$Man | Ok allu can do with what u got is wire the sub in 4 ohms sooo just wire ur + terminal and - terminal to the + and - terminals on the amp.Since the sub is a single voice coil u cant wire it any diffrently Good Luck |
| thanks man..i went to thunder bay ont and went to an audio center to test how loud it was in my truck and the guy said it was best because i had a ford ranger(small)..he said if i had a 12' i would blow my back winwod out if i turned it half way...so next month i'm geting a MTX.thunder 8000 they look cool...wel l8er |
