Radio code scenic II
Username: Reunbleiz
Hi,
Could you give me the code for my radio radiosat :
model no : RENRDW131-10
RNRD0340207854
PROD No : FD0604390207854
8200300858TQ487
8200 300 858 --B
Thank you
Username: Hay88
PortsmouthUk
Post Number: 2606
Reunbleiz
your code 9575
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press Preset " 6 " to Enter
