Renault Clio 2003 Radio Code please!
Username: Annie98
Could anyone tell me the code for radio in my Renault Clio, 2003 model.
Radio Model No. 22DC278/62B
Prod No. FD0302480331685
Username: Hay88
PortsmouthUk
Post Number: 2564
hi post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
Username: Annie98
The r numbers on the radio were:
TOV779
RN278F20331685
Hope this is what you mean?
Username: Hay88
PortsmouthUk
Post Number: 2571
Annie98
your code 4227 you must hold at the end to store code
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Username: Luisreynoso
Villa de Alvarez_%_160516, 7 36
Hay88 hi!!...can you give me the code if i have the engine and chassis number?, I would not board Demont, thanks!
Username: Annie98
Hi, I tried the code 4227 but it didnt work?
Username: Hay88
PortsmouthUk
Post Number: 2584
hi annie98
please check TOV779 = 4227
if its T0U779 Then code 5220
