2003 acural tl type S radio code needed.
Username: Charlie2900
Replaced the battery and now the code i have does not work.
Bose cd player serial# U3001 L3197
2003 Acura tl type S
Thank you for you help
Username: Regrooster
Post Number: 5469
If you can provide the necessary information then your ACURA code is available here for free
https://radio-navicode.acura.com/?src=inq
If not then the code will only be available from your local Honda Dealer or a Decoding Service ...who will plug in a laptop to read/recode your memory chip (EEPROM)
