lost my radio now for 3 months....code in manual does not work, i really miss chris moyles and scott mills, can anyone help!!!!! model no: 22dc278/62b prod no: fd0201460087385 tok719 rn278f10087385 8200057681--b 8200057681tk719 0087385 thank you in advance
Clio1234 your code 4528 you must hold at end to store code. Code Entry as Follows:
Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
Posted on Thursday, September 30, 2010 - 11:31 pm: Hi can anyone help me unlock my radio. I changed the battery yesterday and do not have the code from the last owner
Renault CLIO Radio Code Help !!!! Help! I need a code for my radio Renault RNRD5950014521 RENRDW220-60 FD0105370014521 8200483751T F398-SECURITY 0014521
Posted on Tuesday, October 05, 2010 - 09:10 am: Renault CLIO Radio Code Help !!!! Help! I need a code for my radio Renault RNRD5950014521 RENRDW220-60 FD0105370014521 8200483751T F398-SECURITY 0014521 ==================================== Try code 4 7 7 5
Torpedillo your code 9386 you must hold at end to store code. Code Entry as Follows:
you need to remove the radio. they are too small holes each side of the radio use an old metal coat hanger 4 darts or very small screwdriver or long nails. put into holes about 4-5cms and push outwards sideways and carefully pull radio forward. you must do the holes on each side at the same time
Then post the numbers/letters from below the main barcode something like 7700xxxxxxtt123 or 8200xxxxtt123 or the security code like Q123 or T0U123 can be found in a small box then i can help you off of the radio
We did remove the radio, did exactly that.. we wrote every number down we saw, but the security code looked like it had been scrubbed out, and the last few numbers of the 8200xxx code aswell. Maybe the garage did it, we aren't sure. Can you help otherwise?
Hi. Pls can anyone help me to get my radio working again - Renault Clio. Here is stuff from the side of the radio: Model 22DC258/62B PRODUCT NO: FD0202090200110 RN258F20200110 TO 0362 BAR: 8200057673TO362
Leonardochen your code 8895 you must hold at end to store code. IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ] button then rotate the thumb wheel for the correct first digit Press the [ ] button then rotate the thumb wheel for the correct second digit Press the [ ] button then rotate the thumb wheel for the correct third digit Press the [ ] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL press the first preset button for the 1st digit, second button for the 2nd digit third button for 3rd digit forth button for 4th digit then press and hold buttons 6 to store. for 10 seconds
Post Number: 1 Registered: Oct-10 Posted on Monday, October 18, 2010 - 07:18 am: Hi, if someone could provide the code for my Clio radio model no : 22dc239/62 T0N720 RN239F0030398 prod no : FD0203260030393 -----------------------------------------------------------------------
Payche your code 6045 you MUST hold at end to store code. Code Entry as Follows:
Switch Radio On - Display Shows " CODE " Then " 0000 " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press and hold preset " 6 " To Enter
if I913 Then code 8141 you must hold at end to store code if L913 then code 2142 Code Entry as Follows:
your code 6495 you must hold at end to store the code. Code Entry as Follows:
Switch Radio On - Display Shows " CODE " Press " " On The Stalk Control To Enter " 0000 " Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
Kamilelt your code 5169 you MUST hold at the end to store code.
your code 9530 you must hold at end to store the code. Code Entry as Follows:
If your happy with my help PayPal donations to my Code Calculator Software Fund are always most welcome payments to: codehelp@hotmail.co.uk
Markes_taipas your code 5619 you must hold at end to store code. Code Entry as Follows:
Switch Radio On - Display Shows " CODE " Then " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
Please help!! Renault Clio 2001, 1.2 Lost the code for radio Model no: 22DC258/62B TOQ139 RN258F10140560 product:FD0201470140560 BARCODE:8200057673TQ139 Thanks!!!
Please help!! Renault Clio 2000, 1.6 Lost the code for radio Model no: 22DC259/62F TOI861 RN259FY00620077 product:FD0200050062077 BARCODE:8200029539TI861 Thanks!!!
I've lost the code for the radio in my Y reg Clio 1.4. I'd be grateful if someone could forward the code for it to me - I can't live without music in my car!!!
Please help!! Renault Clio 2000, Lost the code for radio Radiosat 4000 Model no: Philips 22DC451/62E 902221451622 Product. no. FD 10 99 27 2125482 BARCODE: 7700433073V423
Hi, I would be grateful for any help getting the code for my tuner list cd player. model 22dc279/62z product fd0202260318712 rn279f20318712 barcode 8200002607t0119 Thanks in Advance
Redbuller your code 1802 you must hold at end to store. IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
FOR NO STEERING CONTROL press the first preset button for the 1st digit, second button for the 2nd digit third button for 3rd digit forth button for 4th digit then press and hold button 6 to store. for 10 seconds
Hay88, Thanks for your help.Code was actually 1902. Tried 1802 but wouldnt work so i tried 1702 and then 1902 which worked. Thanks a lot glad to get it working again.
code 0528 you must hold at end to store. IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
can you help please, i need a code for my renault clio radio number:RENRDW121-01 product number:FD0504300009372 RNRD0940009372 8200269038TM875 8200 269 038 --A
Azze code 0312 you must hold at the end to store the code. Code Entry as Follows:
Post Number: 1 Registered: Nov-10 Posted on Wednesday, November 24, 2010 - 02:58 pm: Please if you can help ne I have reno clio and i dont have radio code model 22dc258/62b top 465 rn258f20324464 prod:fd0302480324464
Mel31 hi post the numbers/letters from below the main barcode something like 7700xxxxxxt123 or 8200xxxxtt123 or the security code like Q123 or T0U123 can be found in a small box then i can help you
mel31 code 7055 you MUST hold at the end to store the code. Code Entry as Follows:
hi i have a renault clio van and my battery went dead and ive no code :-( im wondering does anybody have a code ?
my radio model is 22dc239/62t its product number is fd0002100014599 its bar code is 8200113801tn721 and its rn code is rn239f20014599 thanks very much for the help i appreciate it, great forum!
TOD275 = code 0394 you MUST hold at the end to store the code. Code Entry as Follows:
Hello, I would appreciate if someone could help me with the code to my old Renault radio. Details are: Serial: rn451fx2113588 Barcode: 7700433073C515 Model: 22DC451/62E Production Number: FD1099182113588
Mrwee code 0908 you MUST hold at the end to store the code. Code Entry as Follows:
Please help with code for my Renault Clio I bought from used car dealer. Model No. 22DC279/62F TOW767 RN279F10149864 Prod No. FD0301130149864 Bar Code: 8200029541TW767 Thanks in advance!!
code 3285 you must hold at the end to store the code. Code Entry as Follows:
Gbl3587 you need to remove the radio. they are too small holes each side of the radio use an old metal coat hanger 4 darts or very small screwdriver or long nails. put into holes about 4-5cms and push outwards sideways and carefully pull radio forward. you must do the holes on each side at the same time
Thanks hay88, i have actually found the code..........to my surprise, the previous owner has wrote it down on a tiny bit of paper included with the manuals.
Hey guys, Ive lost my code for my renault clio wonder if you could help me. its pretty hard to find any garage round by me who does any sort of radio decoding so I though online is the best way.
My numbers are below: Model: 22DC278/62B Prod: FD0403040368850
hi i need help with a code for a renault clio all the numbers i could find are below Renault 8200409475 RNRD3450049191 RENRDW220-00 FD02 0502 0049191 8200409475T H170-SECURITY thanks
Calumwelsh code 6461 hold at the end to store code. IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
hi .. want help to unlock my yahoo Dash clio 2004, I disconnected the battery and I have no ususraio manual that I bought the car used. Would greatly appreciate the help as you can dsfrutar my car completely. autoestero details Model: 22dc 239/62T tot: 903 RN239F40005017 Prod: HC0004140005017 8200113801TT903
Cmq73 code 6041 hold at the end to store the code. Code Entry as Follows:
