I need a code for my Renault Laguna 2004 CD. The following are the information on the CD: Model No:RENRDW100-10 Security: T949 RNRD0140216408 PROD No: FD404370216408 8200247962TT949 8200 247 962 ---B Made in France.
These are all the numbers I see on the reverse side of the CD.Please try to explain how to go about inputing the codes as well as other necessary information.
Gani009 your code 6063 you Muat hold at the end to store the code. Code Entry as Follows:
Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
