Kick panel... pod things
Username: Deadrabit
Marionville, MO
Post Number: 2565
http://www.youtube.com/watch?v=kUI-aFzijz8
this guy looks like a goof....
any one ever heard placement like this?
i don't mean to post so much! just found this interesting... considering doing that for my self if some of you think its a good idea.
Username: Canaanwhite
Monroe, Louisiana USA
Post Number: 183
lol...... what a nut
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 117
With that big nose and a-pod in front of his face, that van is a road hazard
Username: Southernrebel
Post Number: 8359
Yep.
From what I gather, the guy really does know WTF he is talking about.
That van was a 3-4issue build in CA&E Mag. They called it "The build no one would do" or something like that.
Hell of a read.
Post Number: 185
its still a driving road hazzard no matter what he knows about SQ
Username: Deadrabit
Marionville, MO
Post Number: 2566
well canaan! thanks for that advice! i think other than having my kicks down low i am going to copy something like what this guy did.
i drive a wall daily.. my car is already a road hazard!
i would like to get a better understanding of what glasswolf was talking about when it comes to pointing the speakers off the windows to ur ears
Post Number: 187
yw
Username: Deadrabit
Marionville, MO
Post Number: 2567
canaanwhite.... u post a lot.....
do u know me or something? seems like every time i post u post
Post Number: 8361
If you drive a walled vehicle daily...rear-fill is the least of your worries.
In the build from the vid u posted, that it just trying to obtain the best on-axis response w/ minimal refraction. Your front and side windows, as well as the dash can cause all kinds of havoc w/ sound refraction. Having a large mid/high enclosure on axis w/ the listening point can greatly improve SQ.
But, even w/ a perfect positioning of mids/highs/subs....the car audio environment is far form an anechoic chamber.
Post Number: 189
I'm just trying to get my post count to Gold Level intime for Secret Santa
Username: Makinblak
Post Number: 122
Hahaha there are so many things wrong with that statement
Post Number: 224
Username: Deadrabit
Marionville, MO
Post Number: 2569
alright. thanks canann.
ill post some pix has i build. i might only have time to do one side at a time. but i do have a ? for glass wolf about time alignment
with my set up i am not sure if i have anything way to align my tweets and mids that are next to each other.
so i was also considering building the 6.5s a little more forward than the tweeters so the voice coil on the 6.5 and the tweeters will be the same distance away from my ears.
thoughts on this ?
Post Number: 233
that should help make the sound arrive at the same time by insetting your tweeters like that
Username: Deadrabit
Marionville, MO
Post Number: 2571
canaanwhite... please stop posting on my stuff !
thanks
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 15808
x2
Username: Deadrabit
Marionville, MO
Post Number: 2572
thoughts on the tweeter and 6.5 voice coil alignment?
Post Number: 15821
wish i could help you but i dont no much about this kind of stuff
Username: Deadrabit
Marionville, MO
Post Number: 2573
thanks sean.
hope glass wolf sees this
Post Number: 15897
your welcome
Username: Deadrabit
Marionville, MO
Post Number: 2574
i was going to get started on this today........ but i had to get my fiberglass from my friend and he wouldn't stop talking to me so it was dark when i got home
Post Number: 15963
oh well youll have more free days
Post Number: 267
you seem a little brisk dBlk ?
Username: Deadrabit
Marionville, MO
Post Number: 2575
i have been stressed... and building something always helps me calm down
Post Number: 277
I'd like to see pics of your setup when you build it...
Username: Deadrabit
Marionville, MO
Post Number: 2576
i have pix of my build that i have now.... i am sure the wall build is more fun to look at than these ugly things i am about to make
Username: Glasswolf
Post Number: 14213
driver alignment. I'd shoot for a cross-car pattern. aim the passenger pod at the driver, and driver pod at the passenger, so to speak, so you get a somewhat wider sweet spot where both sides cover the same area. You could get a rough idea of that using the propsed driver position, then using a laser pointer aimed directly where the speaker will be pointing, placed where the speaker will be. Then arc the laser 30 degrees from center both left and right to get a rough idea of dispersion angle for each driver.
That's a decent way to start.
also; fiberglass is the last step. you first need to find the proper speaker placement, then tape them in place and give it a trial run for soundstage and imaging to see if they work where you put them (cardboard templates work for this.)
Then you need to make the wood forms to hold the drivers using a circle jig and a router, and a jig saw. (that's one way to do it)
Once the wood forms are cut, then you stretch the cloth over them, staple in place, and resin the cloth, etc..
Username: Deadrabit
Marionville, MO
Post Number: 2577
i think i am talking about something a little different. i am talking about the tweeter and the 6.5 that r next to each other.
i was thinking about making the 6.4 coil and the tweeter the same distance away from me. so the tweeter will be set back inside of the pod more than usual
