Lost signal
Username: Blackman
Saint john, Nb Canada
Post Number: 28
will plastic bag over dish help in heavy rain or snow?
Diamond Member
Username: Nydas
Post Number: 20187
People have done it. Signals travel through it anyway.
Username: Old_howard
Post Number: 123
roy.......do NOT listen to Nydas biotch...she try to blow up yur house and kill your box...she is a pathetic pc of chit that know nothing
Username: Never_on_sunday
Post Number: 82
Put a Zip Lock bag over your LNB
Spray your dish with Pam cooking oil.
Username: Blackman
Post Number: 29
will try plutos suggestion thks
Username: Hardrockstriker
Post Number: 1045
You can put whatever you want over your dish, but there will always be a bit of signal loss (from glass, plastic, etc). So having a bit of snow on your dish may not be any worse than what you lose from physically shielding your dish. also if you live further north where you get snow then your dish should be more vertically angled as opposed to facing the sky. IMHO, i would just leave the dish alone.
Post Number: 124
Move to Florida roy
Diamond Member
Username: Nydas
Post Number: 20188
Roy: Jason Bourne is more knowledgeable in this matter than me, so I suggest you follow his advice.
Username: Private
Post Number: 17
roy t johnsonBronze Member
Username: Blackman
Post Number: 29
Posted on Sunday, November 28, 2010 - 09:16 am:
Username: Doreenakadj
Post Number: 5339
WOW.... Nalin are you not feeling well?... you just ........... never mind ...you'll be back to your old self soon enough.
Post Number: 5340
I can't believe Nalin left me speachless... ( first time ever)
Username: Bazuka2020
Post Number: 957
Dish is galvanized you dont have to do that
