Code for renault megane expression + 2001
Username: Elharry
NewtownWales
Hi
Life`s a real drag without music in the car,Is there anyone who can tell me the code for my renault megane expression + (2001)
the no below the barcode on radio is - 7700434422tu698
The Model no is - 22dc259/62t
Product no is - fd0400490255872
Any help Greatfully received
CHEERS
All the best
Harry
Username: Hay88
PortsmouthUk
Post Number: 2463
Elharry
your code 5382 you MUST hold at the end to store the code.
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
