hi, I recently bought an old renault clio 2000 1.2 and have been unsuccessful in entering the code. Can anyone help me with the code to my blaupunkt : Blaupunkt Werke gmbh Made in Portugal BP8124X7833545 Renault Ho Rds 7648124391 021253
Discover777 your code 8352 you must hold at end to store code. Code Entry as Follows:
Switch Radio On - Display Shows "Code" and then " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
