Renault Radio Code
Username: Twinbat2
Willoughby, Warwickshire United Kingdom
Hi,
I need the radio code for my Renault Clio 1.2v Expression 2003
Model no: 22DC278/62B
RN278F30509476
PROD NO: FD040325059476
8200057681TJ615
Can Anyone Help??
THANKYOU
Username: Hay88
PortsmouthUk
Post Number: 2335
Twinbat2
your code 6777 you must hold at the end to store the code.
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Username: Twinbat2
Hi Hay88
thank you so much for the code. I have followed your instructions and every time I input the correct digit and press the stalk control it just beeps and the number keeps on flashing??
I can't seem to get it to store the number?
Help what am I doing wrong?
Username: Hay88
PortsmouthUk
Post Number: 2349
you must hold it in for about 10 seconds
you can try holding down button 6 to see if it will store.
8200057681TJ615 < is off of the radio and not a book?
Username: Twinbat2
yes the code is off the radio, and not the book.
I have tried as you explained, holding down button 6 and it gives me an ERROR code. So not sure if the error is the code or if I am not storing it correctly? Sorry?
Username: Hay88
PortsmouthUk
Post Number: 2375
Twinbat2
can you please recheck the last letter and three digits of 8200057681TJ615 thats what is needed for the code.
ERROR code = wrong code.
so please check that J615
entering as above or you can try.
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and hold buttons 6 to store. for 10 seconds
Username: Twinbat2
I've re-checked the code and it is correct, I will try it the other way.
I am just waiting for it to reset itself at the moment as its still says ERROR.
Thank you
