Silver Member Username: NissankickerGrambling, LA USA Post Number: 308 Registered: Mar-06 | As of tomorrow ( Oct. 20,2010 ), I'm putting: 6 12" Hifonics HFD4s 1 Autotek AT-2000.1 Custom Ported Enclosure ... In my 1999 Nissan Sentra GXE ( 4-dr ) My question(s): 1) How do you think it will sound... 2) Do you think it's " overkill ".... 3) Etc..... I will be posting videos and pictures of the entire build & all items... ... I'm just lookin' for advice ( good & bad ), suggestions, etc... THANK YOU! |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1505 Registered: Sep-09 | not fond of Hifonics, never heard of Autotek, do you have the power to backup that 2k amp if it does put out rated power. what electrical upgrades do you have? have you done your big 3? got a high output alt? nice battery? 1/0 ga wiring? |
Silver Member Username: NissankickerGrambling, LA USA Post Number: 309 Registered: Mar-06 | I have Big 3 Installed ( 2 runs of 4ga each )... Stock Alt... ( never had any voltage problems... )... Extra Battery ( Of course! ) - 2 Runs of 4ga wire from Front 2 Back - including Ground ( 0/1 is VERY high in this area - $6 per ft. ) |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1507 Registered: Sep-09 | http://www.knukonceptz.com/productDetail.cfm?prodID=KCA0BK-50 |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1508 Registered: Sep-09 | if if you want copper instead of cca. http://www.knukonceptz.com/productDetail.cfm?prodID=KFX0BK-50 |
Silver Member Username: NissankickerGrambling, LA USA Post Number: 311 Registered: Mar-06 | Thanks for the info... ... NOW BACK TO THE TOPIC ON-HAND! Advice, Suggestions, etc.... |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1509 Registered: Sep-09 | yes you will have a FUCKTON of cone area but you may do better with 2 larger drivers on the same power. i would also suggest a sundown amp or a audioque amp. those subs probably wont sound that great even tho there cheep ans its easy to just add cone are. however i would love to see this build and what it puts up on a TL. do you have a front stage that will keep up with sub stage? whats your final ohm load going to be? |
Platinum Member Username: Rovin1 15 = 153 DBs ...Trinidad & T... Post Number: 16741 Registered: Jul-05 | deathoob never hear of autotek = deathnoob j\p lol autotek was very good a few yrs ago but now the quality has dropped hifonics isnt the choice of most of us on E ... |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1512 Registered: Sep-09 | i would like to see clamped power on that amp, my amp did ~2200 apparently when i when't to the last show, not bad for 2 ohms. also hush rovin, only been in car audio for ~3-4 years now and only a year or so not failing at it. |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 15633 Registered: Jun-04 | x2 |
Silver Member Username: NissankickerGrambling, LA USA Post Number: 312 Registered: Mar-06 | Yes... Right now I have JVC HXs 6.5s Coaxials in the Front stage w/ 6 tweeters accompanying them. - Mid Stage: Interfire Slims 6.5s w/ 1 tweeter each side accompanying them. - Rear Stage: Kicker KX 6.5s. .... When I figure out what highs amp I wanna use PERMENANTELY I'm gonna install my Component sets ( 5 sets - 1 in each doors - 1 in the rear dash ) Total of 16 speakers & 18 Tweeters ) ... But musical wise: It's CRYSTAL clear with the interior speakers I have now on a " Death Wish 360 " ( Old School Amp for the record )... ... I will be posting Pictures and a couple Videos of EVERYTHING - The 6 12s, the Autotek 2000.1, and the enclosure build. |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1513 Registered: Sep-09 | how about this as a mids and highs amp? Information on the new SAX-200.4 can be seen hear Official Ratings off SAX-200.4 : 200x4 at 4 ohms 300x4 at 2 ohms 400x4 at 1 ohm 600x2 at 4 ohms 800x2 at 2 ohms Actual tested - factory supplied figures : 210x4 at 4 ohms 350x4 at 2 ohms 465x4 at 1 ohm 665x2 at 4 ohms 925x2 at 2 ohms |
Silver Member Username: NissankickerGrambling, LA USA Post Number: 313 Registered: Mar-06 | That's d*mn good... ... Will keep that in mind ( definitely! ) |
Platinum Member Username: GlasswolfPost Number: 13967 Registered: Dec-03 | Personal opinion? it's overly complicated. |
Gold Member Username: Loc_outSoCal Post Number: 3253 Registered: Feb-05 | You might want to upgrade to 0/1. This way you can add more power to them sub's. |
Silver Member Username: NissankickerGrambling, LA USA Post Number: 314 Registered: Mar-06 | @ Glasswolf... true... but i like complicated. @ LowLife... Yeah, you are right... I'm gettin' to that as we speak ( type that is ) |
Platinum Member Username: GlasswolfPost Number: 13975 Registered: Dec-03 | I don't. too many things to go wrong, too many issues with things like soundstage, imaging, beaming, signal path lengths, cancellation, etc. Keep it simple and you won't have nearly the issues with getting a good sound system. I guarantee you I could set up a better sounding system with one 3-way component set in front, one pair of midbass drivers in back, and two subs, all running active. simple, clean. |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1517 Registered: Sep-09 | want to play with my car glass? |
Platinum Member Username: GlasswolfPost Number: 13981 Registered: Dec-03 | maybe ^^ |
