Renault Megane Alize 1999
Username: Keithandrew
Need the radio code please.All i know is it is systemes audio philips and the only number i can see is
3111 115 33652
Does that make any sense?
Thanks for your help
Username: Hay88
PortsmouthUk
Post Number: 2347
Keithandrew
you need to remove the radio.
they are too small holes each side of the radio
use an old metal coat hanger 4 darts or very small screwdriver or long nails.
put into holes about 4-5cms and push outwards sideways
and carefully pull radio forward.
you must do the holes on each side at the same time
Then post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
off of the radio
Thank you.Thought tere was a way round without removing radio, will do, thanks again
Thank you hay 88.At the moment i dont have the car so cannot take radio out.However i have found the manual for the radio !! Is this any good?
Model dc942/62
NE 626-77 11 200 935-09 1998
Sorry if i come across as an imbecile but thanks for your patience
Username: Epka
Doncaster
Could you post code for mine radio ? Also Radiosat 6010 from Megane
Numbers are:
7700 426 421 Q596
Model NO : Philips 22DC459/62L
9022 214 59624
Prod No: FD 0898284198860
Code gravage: 4198860
Thank you for helping me,
Evaldas
Thanks, i have actually found my code!!!!
Username: Hay88
PortsmouthUk
Post Number: 2354
Epka
your code 9472
Username: Epka
Doncaster
Thank you hay88. ;)
