hi just wondering any way to save 4.01 version on 3gs. i don't want to loose it ..if somethings happens to my phone or if i accidentally upgrade..and don't want to lock my iphone again
SADA YOU CAN save your shsh by using tinyembrella. also if you wanna update without loosing your firmware .if you need all instruction i will email . ok hi brother lol you got lot of poeple i send you .
Step by Step Guide to Save iOS 4.0.1 SHSH Blobs with TinyUmbrella 4.01.03 for iPhone 3G, iPhone 3GS, and iPhone 4 Apple has released the iOS 4.0.1 update and for All Jailbreakers it's very imperative that you save your SHSH Blobs for iOS 4.0.1 now. And it could be done with a few mouse clicks and tiny little software 'TinyUmbrella' -- Apple by default does not allow to downgrade your iOS version once you upgrade it. And there is no way to downgrade unless you have saved your SHSH Blobs for the previous version already mentioned in details here. TinyUmbrella also has been updated to version 4.01.03 for Windows, MAC and Linux and now supports iOS 4.0.1 and iPhone 3G, iPhone 3GS, and iPhone 4.
Step 1: First of all Download the latest version 4.01.03 of TinyUmbrella depending your Computer OS From below links and save it on your Desktop.
Download TinyUmbrella v4.01.03 for Windows. [http://ifile.it/843torj] Download TinyUmbrella v4.01.03 for Mac OS X. [http://ifile.it/zdvwc2m] Download TinyUmbrella v4.01.03 for Linux. [http://ifile.it/lvu8i2q] Step 2 : Make sure your iTunes version is between 9.0 to 9.2
Step 3 : Launch TinyUmbrella which you downloaded in Step 1, and Plug in your iDevice mentioned above.
Step 4 : Click on ' Save my SHSH ' and It would save the SHSH Blobs (Signatures) for your Device. And save it to the Saurik's server (Cydia) and you can find .shsh file generated earlier on your computer too (see below where) and save it locally.
MAC /Users/.shsh WINDOWS XP <main>:\Documents and Settings\.shsh WINDOWS 7 <main>:\Users\.shsh This would work for all iDevices listed above Whether Jailbroken or not !
