Plz help 98 renault laguna raido
Username: Jonathancash
hi ,iv 4 hours drivein ta do every day and my raido dosin work it keeps askin me for the code,,,plzz help hay88 Philips 22DC459/62E 9022 214 59622 PA4,4*15W,RDS model no;22DC459/62E FD 08 98 23 2073848 PROD NO; FD 0898232073848
bar code is7700 426 483 u169 plzzz help
Username: Hay88
PortsmouthUk
Post Number: 2374
Jonathancash
your code 5809 you MUST hold at end to store code.
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
