New member Username: Bairnsrus
Post Number: 1 Registered: Oct-10
Posted on Can anybody help me with a code for my radio, disconnected battery and now no sounds; Model No: 22DC449/62L Prod No: FD0898244174343 Code Gravage 4174343 M/ch 174174 Many thanks in advance |
Gold Member Username: Hay88
PortsmouthUk
Post Number: 2315 Registered: Mar-10
Posted on Bairnsrus please post the number from below the main fat barcode something like 7700xxxxxT123 |
Post Number: 2 Registered: Oct-10
Posted on Hay88, Thanks for the lightning fast response, the number is: 7700 426 414 J769 |
Post Number: 3 Registered: Oct-10
Posted on Hi Hay88, Thanks for the rapid response, the numbers are: 7700 426 414 J769 |
New member Username: Mistycat
Posted on Please can you help I have a rover with a philips r660 to which i have no radio code serial number :- RG349FS2012707 Is it possible to retrieve radio code from this serial number Your help would be much appreciated |
Post Number: 4 Registered: Oct-10
Posted on Thanks for the help, I managed to find the number on a piece of paper |
PortsmouthUk
Post Number: 2317 Registered: Mar-10
Posted on Bairnsrus YOUR CODE 6526 |
Posted on morning bairnsrus is this the code for me with serial no RG349FS2012707 if this is it thank you so much for all your help new user of this site |
