Reset code
Username: Dogmanass
how do i put radio 6006e 2002 focus in reset mode i can,t get it to ask for code
Username: Hay88
PortsmouthUk
Post Number: 2294
try disconnecting for two mins
Code Entry as Follows:
Switch Radio On - Display Shows
CODE with " - - - - " flashing
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press preset " 5 " to Enter
Username: Dogmanass
radio will not display CODE i,ve disconnected radio from 2 mins to 2 days still will not display CODE any ideas 6006 focus radio
