Renault Scenic Radio Code
Username: Vixcotton
Hi
Could anyone help me with a Radio Code. My battery was changed and the code in the Manual does not work anymore.
Details off side of Radio:
Model No: 22DC278/62R
Prod No: FDo202420024265
Other Numbers??
TOV390
RN278F20024264
8200150474TV390
Thanking in advance
Username: Hay88
PortsmouthUk
Post Number: 2155
Vixcotton
your code 4612
Username: Mikey_cee01
Glasgow
Hey could anyone help me. I need the code for my renault radio. Just bought the car (Used) and there was no code anywhere.
Model no: 22DC258/62P
T0D390
RN258F30109522
Prod no: FD0203170109522
Other : 8200152345TD390
Thanks in advance
Username: Hay88
PortsmouthUk
Post Number: 2159
Mikey_cee01
your code 2816 you MUST hold at end to store code.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Press " " On The Stalk Control To Enter
" 0000 "
Rotate " Thumbwheel " For Correct Digit
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Username: Superhoopsa
Hello
Could anyone please help me with a Radio Code. My battery was changed and the code in the Manual does not work anymore.
Model No: 22DC259/62P
Prod No: FD0501380305335
TOE536
RN259F10305335
7700434424TE536
Thanks in advance for anyone that can help me}
Also i have a code of 3467, but this doesn't seem to work!
Username: Hay88
PortsmouthUk
Post Number: 2163
Superhoopsa
your code is 3476} you must hold at end to store code.
" CODE "
" 0000 "
Thanks Hey88
That worked a treat! i really appreciate your help.
Thanks again!
