Bronze Member Username: John_mosbyVirgina USA Post Number: 40 Registered: Jul-09 | PlymouthPlatinum Member Username: Plymouth Canada Post Number: 14957 Registered: Jan-08 Posted on Monday, October 04, 2010 - 11:39 pm: Gray Ghost List your model! H/P a4313w |
Gold Member Username: DoreenakadjCanada Post Number: 4790 Registered: Dec-06 | http://windows-7-drivers.com/Win7/xp/driversxp/xp-drivers-hp-a4313w.html |
Gold Member Username: DoreenakadjCanada Post Number: 4792 Registered: Dec-06 | Windows XP drivers http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&os=2093&p roduct=4124968&sw_lang= Select your operating system, "microsoft Windows XP" |
Gold Member Username: DoreenakadjCanada Post Number: 4793 Registered: Dec-06 | http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07165&lc=en&dlc=en&cc=us& site=null&os=228&rule=54149&product=4124968&key=null&sw_lang= |
Bronze Member Username: John_mosbyVirgina USA Post Number: 41 Registered: Jul-09 | Doreen, first thanks for your help I'm not sure what to download does this mean I can just download windows XP? what will happen to windows 7? HP Pavilion a4313w-b XP Drivers HP Pavilion a4313w-b XP DriversThis is an automated Pavilion a4313w-b XP drivers . The Pavilion a4313w-b drivers are windows 7 ready. This means that your HP Pavilion a4313w-b XP Desktop PC will automatically find and install all the drivers for your system, with hardly any user interaction. If you have installed a new wind.....lots more xp drivers hp a4313w information here. Instant Download CD |
Platinum Member Username: PlymouthCanada Post Number: 14966 Registered: Jan-08 | Gray Ghost OK your PC can work with WinXP! I recommand that you do a low format before installing WinXP or you will have many problems. After it install XP then go to HP center then download the drivers for XP. Enjoy! |
Gold Member Username: DoreenakadjCanada Post Number: 4796 Registered: Dec-06 | https://www.ecoustics.com/electronics/forum/home-video/655526.html |
Gold Member Username: DoreenakadjCanada Post Number: 4797 Registered: Dec-06 | http://welcome.hp.com/country/us/en/support.html another link for support and drivers |
Gold Member Username: DoreenakadjCanada Post Number: 4798 Registered: Dec-06 | http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02012172&lc=en&dlc=en&cc=us &lang=en&product=4124968 this is all your info on your HP computer |
Gold Member Username: DoreenakadjCanada Post Number: 4800 Registered: Dec-06 | oops |
Gold Member Username: DoreenakadjCanada Post Number: 4803 Registered: Dec-06 | Gray Ghost can you please PM ( private message ) me here... left click on my nick I can email you software to wipe out your drive After its done you can load Windows XP If you need drivers I also have software to find all the drivers for XP If you need windows Xp I can upload that on rapidshare for you to download(its fully activated) |
Silver Member Username: HardingPost Number: 307 Registered: Dec-07 | nydas Platinum Member Username: Nydas Post Number: 19829 Registered: Jun-06 --------------------------------------------------------. If you have Windows 7 Home addition, the following is a no cost method of adding windows XP to your current hard drive where Windows 7 Home Edition is installed. Good for Hrad Drives over 80 GB. Don't try on smaller drives although it may probably work even on 40GB drives. 1. Do a back up of important files on to a USB drive. 2. Download EASEUS Partition Master Home Edition - Free! 3. Read the insturctions and install it. 4. Move all your files to the lower end of the drive using the software. 4. Split the single partition on your hard drive into two or even three sections. 5. Shut the computer down after exiting. Now you can install the WinXP in one of the newly created partitions. Your Win 7 partiion is still fully functional with the Windows 7. If you have the Win 7 Prof or Ultimate, Easeus home edition does not work with it, and you will have to buy the Professional edition of Torrent it down. Happy installing. |
Gold Member Username: DoreenakadjCanada Post Number: 4806 Registered: Dec-06 | Full software not trial Please remove the * between h0tfile.com ( |
Silver Member Username: Pirate_pete_208Post Number: 259 Registered: Jan-10 | Doreen look for Pest Control he will be posting next....OK |
Gold Member Username: DoreenakadjCanada Post Number: 4808 Registered: Dec-06 | hummmmmmmmmmmm ok |
Platinum Member Username: NydasPost Number: 19835 Registered: Jun-06 | I am sure Doreen's URL will work well. |
Gold Member Username: DoreenakadjCanada Post Number: 4810 Registered: Dec-06 | it does Nalin.... I downloaded it myself today and scaned it for viruses ....there is none but please use at own risk |
Platinum Member Username: NydasPost Number: 19839 Registered: Jun-06 | I also have the Professional version of Easeus. It is good software. |
Gold Member Username: DoreenakadjCanada Post Number: 4812 Registered: Dec-06 | |
Platinum Member Username: NydasPost Number: 19843 Registered: Jun-06 | I also have the Professional version of Easeus. all this software costs money; however, I get it always as a part of some software contract I am doing. I charge less but always insist on good quality software to be supplied by the company I am developing for. One of the advantages of working on contracts - you accumulate a lot of good software. |
