Home theater set up
Username: Ponmayil
I am planning to set up a new home theater in my 11feet X 21 feet room. Planning to buy Yamaha Aventage RX A 3000 reciever , Denon DNA 7100 Recievers. Speakers yet to decide and i am welcoming the forum members valuable suggestion on the above all .
Username: Plymouth
Post Number: 15023
Mayil
Which amp you think used with your DNA 7100?
Username: Ponmayil
Hi , Denon DNA 7100 is a DTS/Dolby audio processor . Is it require any amplifier in addition to this? . I thought Denon DNA 7100 can directly connect to speakers. I am totally new with this kind of set ups.Earlier i used Onkyo standard DVD home theater . Pl suggest the best home theater set up with a budget of 6000$ to 7000$ .
Username: Plymouth
Post Number: 15024
Mayil
If you like Onkyo, go for it!!
Username: Ponmayil
Plymouth , I used onkyo already . Now i want to set up better than that
Username: Plymouth
Post Number: 15025
Ok I vote for a Denon AVR5308CI with Klipsch Synergy F-30 Theater System
http://www.nextag.com/Denon-AVR5308CI-Home-Theater-587411976/prices-html
http://homespeakersdirect.com/closeup.asp?cid=63&pid=688&offset=0
Username: Vm8444
TorontoCanada
Post Number: 335
Mayil
Hi ,
Plymouth is right ,
but that will cost you your whole budget.
Maybe the yamaha or the denon 3311 or nad
which I own older one.
http://nadelectronics.com/products/av-receivers/T-775-A/V-Surround-Sound-Receive r
http://www.audiogon.com/cgi-bin/cls.pl?miscrcvr&1289327711&/NAD-T775-AV-Receiver -with-manu
used seperates from audiogon is safe too but..
start with these front 2
paradigm studio 60 version 6:
http://www.audioreview.com/mfr/paradigm-reference/floorstanding-speakers/studio- 60/PRD_120362_1594crx.aspx
with the paradigm cc490 center and either the studio 10 as rears.
I have the gloss black all around really beautiful looks and sound.,
or the
adp 590 by paradigm[dipole] on side wall or 7.1 use the 10's on back wall too.
tweeter and woofer from this years paradigm reference studio line is similiar to there top of the line signature series.
match with with any axiom sub ep 175 or higher,
then with audioquest type 4 speaker wire
at least for front 3 spks
then flex 14/2 by audioquest for rear.
and you've achieved audio bliss.
http://www.audioreview.com/cat/cables/speaker-cables/audioquest/type-4+/PRD_1163 84_1584crx.aspx
please let us know how it turns out ok?
I'm so confident with nad and paradigm that no audition is needed.
he he
theaudioguy.ca
Username: Plymouth
Post Number: 15027
Good choice Vince!
Nad T-775 is a great choice which will perfectly match with the Klipsch, the smoothness of Nad with the power of the Klipsch must be a great choice!
Sorry I posted the bad link for the Klpsch, the good one is 2400$ but the link give Klipsch RF-82 II Theater System 3334$, So I prefer this kit with the Nad for a great improvement of his system.
Username: Ponmayil
Thanks for the suggestions . I ll try and let you know the feed back .
