Tam69 your code 6042 you MUST hold at end to store code. Code Entry as Follows:
Switch Radio On - Display Shows " CODE " Then " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
