Best place to buy?
Username: Skdooley
Roanoke, VA Usa
Post Number: 1298
Where would you guys say is the best place to buy distribution blocks and a voltage display gauge? I want to get rid of my capacitor. I'm going to need 1/0 gauge distribution blocks that will convert into 4 gauge outputs then a voltage display to monitor voltage.
Username: Tejcurrent
Post Number: 2613
Ebay
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5829
Best buy..Walmart ...target...home depot
Username: Nd4spd18
Philadelphia, PA
Post Number: 11559
ebay.
or onlinecarstereo or sonicelectronix
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 181
http://www.parts-express.com/car-audio.cfm
Username: Livin_loud
MW2 Addict
Post Number: 3281
get a distro block wherever you can easiest, they're all the same thing other than the connection type. voltage display, just search until you find one you like. i have one by tsunami.
