Renault Scenic 2 radio code
Username: Tam69
Hi, This is a wonderful site, and I'm wondering if someone can please help me with my radio code:
RENRDW132-10
T933 Security
RNRD0440071456
Prod No. FD0404160071456
8200300859TT933
I was advised to unhook the battery, because my boot won't open... NOW, my boot wont open, my electric windows are acting up, and my radio is dead...
Username: Hay88
PortsmouthUk
Post Number: 2051
Tam69
your code 6042 you MUST hold at end to store code.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Then " 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Username: Tam69
hay88,
Many, many, many thanks )
